I7 2600k
glen24
Hey every1 I currently have an i7 920do @ 3.7ghz, 12gb ddr3 and use my machine mainly for gaming / recording ingame footage and re encoding them, would it be a suitable upgrade to go for the i7 2600k, Asus p67 pro, 8gb ram and 120gb ocz vertex 3 ssd costing me £608.
Thanks in advance
Sent from my iPhone using AVForums
Sniper Ash6
IMO you're probably best off skipping Sandy Bridge and waiting for Ivy Bridge.
namuk
you will only gain a better overclock speed over the i7 and not worth the upgrade, the Real replacement for i7 is socket LGA2011 at the end of the year, basicly look at the i7 Sandybridge as the i5 before i7 came out later on.
if you had a socket 775 then i would say yes as it is a worthy upgrade.
save your money and wait for 2011 socket. :)
shadowboxer
Yeah would completely agree, it'll be a total waste of money to upgrade from your current system. Wait for LGA2011 or Bulldozer to see how they perform.
In the meantime, no reason why you cant get the SSD as the Vertex 3 is backward compatible with SATA II (assuming you current mobo doesn't have SATA III).
Why not push you i7 a bit further and aim for 4GHz+ - not going to make much real life difference in performance but will keep you occupied.
RyanMartin1993
then by the time he gets round to asking if he should buy that you will tell him to wait for the next one :p
I think you should go for it. Processors are constantly changing don't wait around for anything, unless its literally 1-3months away which ivybridge isn't. If ivybridge turns out to good then you can sell your old stuff and go for that. As far as with the sandybridge goes i think the difference between the i7 2600k and the i5 2500k is very minimal. I would say go for the 2500k and save the extra £80 or so and put that towards a nice beast of a CPU cooler.
Sniper Ash6
:laugh: Wanna bet?
There's not enough of a difference between the 2500k and an OCed 920 to warrant the price, hence me saying it's worth waiting until Ivy Bridge.
namuk
but the true Successor to i7 is ivi bridge Lga2011 socket, going sandybridge from I7 is a pointless exercise and a waist of money.
shadowboxer
:laugh: Wanna bet?
+1 Completely agree!
glen24
true, i decided not to go with sandybridge and instead went for the ocz vertex 3 120gb ssd and here are my results on a sata 2 port.
shadowboxer
Great choice! Very good read speeds there, will be even better when you get a SATAIII system later!
