i wonder if it is okie
Discussion in 'Home Cinema Speakers' started by tinytok, Oct 25, 2001.
  1. tinytok
    tinytok
    Hi guys,
    I've got a Roger speaker system setup which i need opinion
    LS 330 120W Max
    C330 60W Max
    R330 60W Max
    ASB 80W Sub
    I using Marantz SR5200 DTS Amp to drive all these speakers. This amp is rated 6*85W. Will it damage my speakers if i'm or am not using the subwoofer out ?
  2. riddler
    riddler
    The amp cant damage the speakers if its wired correctly.
    Only you can damage then.
    If its distorting turn it down. Simple as that.
    This is assuming your not doing anything wierd like using a rear surround channel to power a passive sub.
  3. tinytok
    tinytok
    Thanks for the reply.
