Hi Guy's,
I'm hoping you can help.
In my vehicle I have a Pioneer AVIC-X1 where the motorised pop out screen is rather dim and when trying to change the volume on the snap-out section the contact must be worn as it quite often does not work or I lose power. Basically its old and tired!
What do you guys advise as a compatible replacement head in order to make use of the existing Pioneer add on units (CD changer and DAB radio) please?
I'm stuck with a 1din dash slot. I also use the built in navigation and reversing camera facilities.
I look forward to hearing back from you.
Thank in advance
Thank in advance
