Question I want to mount my Acer X34 onto this thin drywall opposite to my bed. How can I do it?
ChampionJoe
This wall is occupied by a window and a space where the curtain pole will be, however there's a space above the curtain pole and on the sides of the window where I might be able to mount the monitor with an arm-like extension and angle it downwards. The only problem is the wall material is pretty weak. Any suggestions on how I can mount this thing in a way that it looks good? I really want it to be directly opposite my bed.
