Proto Omega
Established Member
However all the 3.5mm Stereo Plug to 2 Phono Leads that I have seen the 3.5mm stereo input does not go into the DS properly...its keeps coming out as the DS is designed in a way where the back of it is protruding out from the rest which makes it difficult for these kind of leads to go into it. headphones go into it fine but the 3.5mm Stereo Plug to 2 Phono Leads are usually too big and while it will go in, its pretty loose because of the round part of the leads and the design of the DS preventing it from going in properly. Is there a lead I can order that is small and is about 3-5metres in legnth. (in the UK)
I bought this lead http://www.tvcables.co.uk/cgi-bin/tvcables/PH203.html
but the round part of it is too big and doesnt properly fit into the DS.
