I want to do it ... but I'm scared !!! Which box to get?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by diggerbarnes, Sep 17, 2007.
  1. diggerbarnes
    diggerbarnes
    Jul 11, 2006
    141
    I am about to take the plunge into ordering Sky HD BUT ... been reading through the threads ... auto-power downs, excessive fan noise, jerky images, failed recordings.
    If I get one I'll be connecting it to a Pioneer PDP-508XD via HDMI.
    So my question is this - when ordering through Sky is there a particular model / version of a SKY HD box that I should insist on in order to eliminate (or minimise) these problems, or is it completely pot luck? :confused:
    I just want to know that it will be reliable and quiet ! Is this possible?
    Thanks !
  2. mjcairney
    mjcairney
    Oct 26, 2003
    7,293
    2
    137
    Airdrie, Scotland
    +1,079
    At the present time, there only is the one model of Sky HD box, so the only choice you have, I'm afraid, is take it or leave it.
    Cheers,
    Martin.
  3. Upholder
    Upholder
    Feb 14, 2006
    250
    Manchester
    +23
    I've had mine since the first day they were issued, I've not had one problem. I suspect that that is the case for most people. After all, people will normally only post if they have a problem or need some sort of help.
  4. diggerbarnes
    diggerbarnes
    Jul 11, 2006
    141
    Ok thats a good point, thanks guys, I feel a little better.
    Now to haggle a deal with Sky ;-)
  5. Martin J.
    Martin J.
    Dec 19, 2006
    1,406
    +175
    My box is quiet and has worked perfectly aside from an odd HDMI handshake issue that cured itself within a few days. If you're nervous about the whole thing, it's best to get the box from Sky, they'll replace it if it does turn out to be noisy or misbehaves in some other way.
  6. gers1978
    gers1978
    Aug 2, 2006
    1,581
    Glasgow
    +173
    Yes, but there are different *versions* of that model, some with Western Digital hard drives and some with SeaGate. My version number ends with an "8" and I have a Seagate hard drive.
    I believe version numbers ending "7" have Western Digital hard drives, which are supposedly quieter than version numbers ending "6" (unsure which hard drives these have)
  7. diggerbarnes
    diggerbarnes
    Jul 11, 2006
    141
    Interesting ... so its the drive rather than the fan that makes the noise?
    I wonder how I can find out for sure which is the quietest model?
  8. WATTS
    WATTS
    Mar 16, 2007
    863
    Black Ops
    +50
    Not sure if you can really. Im on my third box but its been fine for nearly a month now. :thumbsup:
    If you get a noisy box, send out for a replacement. Its what i did because i wasnt happy with the issues i was having and now its bob on! ;)
    Upholder is right of course and for the people posting here with issues there are others not posting that have had a trouble free HD experience! ;)
  9. nickeddle
    nickeddle
    Feb 2, 2005
    352
    North Yorks Moors National Park
    +10
    I think it's just the luck of the draw,I've had my box over a year and it is quiet and I've had no significant problems.
    Bear in mind most people who come on here have problems I suspect that there are more people without than with problems overall.
