I want the best sound out of the PS3 can anybody help me
Discussion in 'Blu-ray & DVD Players & Recorders' started by bailey1987, Jan 11, 2008.
  1. bailey1987
    bailey1987
    Jun 11, 2006
    144
    3
    +15
    What do i need to set all the setting to i have an Onkyo 605
  2. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,973
    Hi mate :)
    Ps3 audio:
    1.Try this, Settings - BD/DVD Settings -BD AUDIO OUTPUT FORMAT(Optical Digital) then select bitstream.
    You will get a warning that some portions of audio may not play.
    Then just make sure that on SOUND SETTINGS - AUDIO OUTPUT SETTINGS you have selected - DIGITAL OUT (Optical) then ticked Dolby Digital 5.1,DTS 5.1.
    2. BD/DVD Audio Optical Format (HDMI) LPCM.
    Receiver settings post here. :smashin:
    http://www.avforums.com/forums/forumdisplay.php?f=44
  3. BrainDrain
    BrainDrain
    Jan 12, 2008
    3
    Hi all,
    I have a PS3, Sony LCD 40" and a Pioneer 1015 Amp. I use the PS3 to watch a bit of bluray and have it conected to the LCD via HDMI and to the amp via optical as the amp does not have HDMI.
    Can any of you tell me if i am missing out on much on the bluray audio sondtrack on movies as it is going through optical and not HDMI.
    Is it worth buying another amp just because of the HDMI audio will i notice any diffrence between them?
    I have the Kef egg speakers if that helps.
    Many thanks
  4. kingfats
    kingfats
    Dec 29, 2006
    36,741
    Windsor
    +8,973
    Hi BrainDrain :)
    Your missing out on HD audio,which to me is just as bigger upgrade as the visual improvement high definition movies give you. :cool:
    Once you've listened to a PCM/TrueHD track from the Ps3 you won't want to go back to regular DD. :D
    Amp advice,try here. :smashin:
  5. lcd-fanatic
    lcd-fanatic
    Jan 1, 2006
    207
    +5
    Can you listen to this TrueHd via optical though as i was told I couldn't?
  6. jon1
    jon1
    Feb 4, 2006
    1,976
    out in the sticks
    +170
    Correct you can not listen to true hd through optical
    Jon
  7. lcd-fanatic
    lcd-fanatic
    Jan 1, 2006
    207
    +5
    How can I get Hd sound from my PS3 then?
  8. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Only via HDMI as PCM. You will need an amp/rec that support HDMI connection.
    AVI
  9. jon1
    jon1
    Feb 4, 2006
    1,976
    out in the sticks
    +170
