I want some new speakers, advice needed.
Discussion in 'TAG McLaren Audio Owners' Forum' started by Bhavik, Jun 9, 2005.
  1. Bhavik
    Bhavik
    Right guys, I'm a little bit stuck as with what to do in regards to upgrading my speakers. The kit I'm using at the moment is a Tag CD20R, PA20R + 125M's with Mission 782SE speakers. Now I love my Missions they are great, but I'm looking at get a pair of front ported standmount speakers for around £1500 or a little extra.
    What do I get, bear in mind they have to be front ported and pretty small but with a big sound? I need them to be fairly slim as well. The main types of music I listen to house, rnb, hip hop, jazz, drum 'n' bass, soul etc.
    I'm very tempted with the B&W 805, but I need to see and hear them first.
    Your input will be much appriciated.
  2. JohnDee68
    JohnDee68
    May 28, 2005
    34
    Glasgow
    Hi Bhavik
    I remember reading the following thread when I read your post:-
    http://www.avforums.com/forums/showthread.php?t=214768
    it is mentioned in it that the 805s needs an powerful amp with a good reserve, but not too sure how much more than 125 (rated)-145W(typical) specs for the 125M's.
    I hope the above link helps.
  3. alexs2
    alexs2
    Nov 13, 2002
    13,895
    +1,674
    It was me that wrote one of the replies in that post,having tried a set of 805s with a TAG 100x5.
    Do listen to them,in your own home with your amps....they are to my ears anyway,excellent speakers,and very clear without being harsh,but they do present a fairly difficult load,and had the 100x5 gasping fairly quickly,whereas with my own amps they're fine.
    You could also take a listen to the Wilson benesch Arcs,which would fit your bill in many respects,and are similarly beautifully made....also maybe the AE I mkIII.
    Listen to as many as you have the patience for,and don't be put off by people saying that B&Ws may sound hard with TAG etc....all of that is personal preference,and I certainly don't like a hard/forward sound,but use a mixture of TAG and Krell,which ought to be a good recipe for that if it was going to happen.
  4. Bhavik
    Bhavik
    Nice one guys, I think I will check out the 805s somewhere. I'm gonna see if I can find the Wilson Benesch website as well.
  5. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    ATC SCM 12? Not ported and a little lower in price at a K for the pair, but outstanding speakers :)
  6. caleb
    caleb
    Sep 30, 2003
    368
    Cape Town (Ex Holmfirth Yorkshire)
    +3
    B&W 805's should be a good choice with the 125's, but you may find they need a sub to fill in the bottom register.
  7. Steve.EX
    Steve.EX
    Oct 17, 2001
    3,096
    68
    +69
    Kef 201
  8. christoph
    christoph
    Jul 10, 2004
    189
    Liechtenstein
    +3
    yes :smashin:
  9. UrbanT
    UrbanT
    Jan 6, 2002
    12,873
    Aldershot, Hants
    +3,034
    The 805's are superb, thoroughly recommended :)
  10. GrahamMG
    GrahamMG
    May 8, 2004
    4,449
    UK
    +192
    I have to admit that I was also surprised at the sound from the new 805S speakers, the treble is a bit "metallic" but in general a far better job has been made of them than the last 805N which was a bitter disapointment for anyone expecting a jump up from the original 805M (like me!). In fact they sound the same or actually better than the 805SIG range.. There is a lot of speakers out there at £1500 or so that demand a listen, the not so well known ones are also worth a go...
