I want music on and plasma too, solution?
Discussion in 'Plasma TVs Forum' started by Vipen, Mar 9, 2005.
  1. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    I usually watch footy with music on in the background or maybe sundays the news or womething. however, i like to hear the tv as well (well some people can multi-task :) )
    anyway, i have an a/v amp and ntl, dvd, etc running through it. the plasma (PW&) has a terminal for speakers.
    when i want to do this sort of thing i don't care for 5.1, so do you think there's anyway to switch my rears to tv and the stereo fronts to music.
    is there some sort of switcher i can use for the rears that won't affect the quality when in 5.1 and/or sync problems with tv?
    i'm not really sure what the output is of the plasma either.
    any suggestions?
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    It's do-able with a speaker switch, but very clunky and naff, I'd never install that type of thing. Better to run some stereo speakers on the plasma, use them for the music is easiest, and TV quietly on the 5.1 Anything else is a wiring nightmare from hell.
  3. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    thanks MAW, i suspected that was the best route. any recommendations for good but small and inobtrusive speakers. my nice table top with the plasma, centre speaker, etc will become quite cluttered. do they do any wafer like speakers or something these days (and cheap too)?
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Maybe something from Jamo might suit? They are cheap-ish, reasonable sound in the main, and they have a decent web site where you can see them, www.jamo.com
  5. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    thanks MAW, i'll launch the question on the speaker site too. i want something quite discreet too.
    cheers
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    Does AV amp have Zone facility? if so set-up zone 2 in same room for music.....
  7. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    HD, I don't think so. I'll have to check, it's a Nad T752. it looks like i'm goping to have to upgrade anyway to get an a/v amp with delay compensation built in. dvd sometimes lags and sometimes doesn't (on the same dvd). not sure why.
    anyway, i plugged ibn speakers to the plasma yesterday but couldn't get a sound out. they were definately working as when i turned up the volume you could hear the hiss. but i couldn't get sound from my ntl box.
    ntl > emr55 > component in on plasma
    any idea why?
  8. Wackojacko32
    Wackojacko32
    Jan 6, 2005
    239
    Pinxton, Derbys
    I dont have a Plasma, or component connection so I will wait for HD to correct me when I'm wrong, but have you connected audio from your E55 to you plasma? Component cables only carry video.
    Not sure if there is a phono input on the Plasma to connect to the E55 output?
    Wackojacko32
  9. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    ah, emr55 has component to plasma and optical to a/v amp. i sat there last night wondering if component carried an audio signal too. so it doesn't.
    hmm, now i'm stuck(ish). have got my xbox going through vga converter which does have two audio outputs on it. maybe i could do something here.
    dammit, i was just relaxing after the stress of wiring and thinking and wiring and thinking. :(
    maybe there's a way?
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    can run a cable from E55 to component input to carry sound
  11. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    HD, can you elabroate on this? i had a look to see what could be done but i'm none the wiser.
    what output from the emr55, i'm using the component 3 cables to the board on the plasma. i presume these are the visual signal. my optical lead to the amp of course. maybe i could send out a phono from the emr55 but not sure it has this. in any case, where would it go into, there doesn't appear to be any audio inputs on the plasma or the dual board (component part).
    ps. what's zone facility? is this common on newer a/v amps? i'm looking at other amps now as might have to bite the bullet (again).
  12. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    HD or anyone know? :lease: i really want to get this sorted asap and get some nice new speakers.
  13. adeyb
    adeyb
    Jul 28, 2003
    243
    Cheshire
    +10
    I have a Sony 1070 amp and it has audio split, I can watch any video input with any audio input, useful!!!
    cheers
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  15. Vipen
    Vipen
    Jul 25, 2002
    779
    +19
    that's interesting adeyb, out of seperate speakers i presume, not a mix through the fronts?
    thanks for replying HD, however, those audio inputs i did notice yet how do you activate them?
    i presumed that the component part of the board (dual) is seperate to the 'other' part which i don't use and as i see it, has the audio inputs.
    i'll try again this w/e and may be coming back for some more help :blush:
    thanks
  16. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    you dont have to activate them you just connect to them and the internal AMP does the rest.............
