I want HD on my XboxMC - tips please :)
Discussion in 'Xbox Forums' started by Waynej, Apr 24, 2007.
  1. Waynej
    Waynej
    Oct 4, 2004
    8,149
    Wales
    +1,337
    I just want you to get an understanding of what I want to achieve before going into my current setup info.
    I have my own games/media room and we now have a HDTV in the living room... I was considering picking up another Xbox 360 console for the living room to stream media (primarily xvid/divx files, music, photos etc) for the rest of the household to benefit from as I'm the only real gamer in the house, so I don;t see a need for an Xbox 360.
    After much thought I figured I may as well shift the old softmodded Xbox into the living room which has XBMC and works fine for what I want it to do. The only problem now is the high defintion. Currently it is in my games/media room connected by composite so it looks very poor.
    Last time I checked these official ms component HD cables were very difficult to come by, I was wondering if that has changed. I realise they are not on sale in the UK so importing is the only option, if this is available I;d appreciate it if someone can point me in the right direction.
    :thumbsup:
    EDIT: Assuming I can easily find the required cable, last time I checked I'm sure I read about some software which is needed to turn your Xbox to 720p/1080i etc - Enigmah or something I think it was called... I can't remember properly.
  2. Chunder
    Chunder
    Oct 27, 2005
    593
    28
    +37
    There are other component cables available; there's a few options listed in one of the other recent threads...
    Edit: [here
    As you've already got XBMC running, you should be able to use and FTP (file transfer protocol) application to connect to the box from a computer; you'll need to get hold of (ideally) the latest version of XBMC, and the Enigmah videomode switch application - and use FTP to copy them over. Again, this is covered in some other threads around here...
  3. Blandhino
    Blandhino
    Dec 30, 2006
    52
    +12
    While the original xbox is just fine and dandy for viewing SD material it struggles with HD...It just doesn't have the processing or graphical grunt for it.
    I have a number of HD files (avi & mkv) and the xbox will play only one of the HD avi files smoothly, the other HD avi files do play but they are very stuttery particularly when there is a lot of action on screen.
    None of the mkv files I have will play at all, although XBMC will play lower res mkv files.
    Although after you enable the HD settings it can upscale SD material to 720p/1080i. However I prefer to output at 480p and let my TV do the scaling.
