I want DOS under WinXP
Discussion in 'PC Gaming & Rigs' started by Mr.The.Spoon, Oct 6, 2004.
  1. Mr.The.Spoon
    Mr.The.Spoon
    Jun 12, 2003
    524
    I'm a Londoner.
    +13
    I found a website with a bunch of old games from the late 80s and early 90s (including Dig Dug, Populos, Mega-lo-mania...) but getting them to work under XP is a right pain.
    I'm half tempted to dig out my old copy of MS-DOS 6.2 and have a 2nd install.
    Anyone know a better way of doing this?
    Oh and if you want the website, I'll PM it to you.
  2. supersonic87
    supersonic87
    Dec 31, 2003
    286
    Swansea, Wales
  3. Marc
    Marc
    Jul 8, 2004
    11,627
    Titchfield
    +1,098
    have you tried using VDMSound? It gives DOS extra memory to run games as well as emulating sound via directsound, and mouse/joystick via directinput. You can get it HERE
    you may also need to get a speed capping program otherwise the game will run hundreds of times faster than it's meant to. Try something from HERE
    good luck!
  4. Ethics Gradient
    Ethics Gradient
    Jul 29, 2003
    3,680
    aka Billy Science - Suni ojna Tas
    +430
    XP / NT doesn't have DOS installed - so that might be where you are going wrong for a start ;)
    XP / NT cores use a command prompt ... but this is not DOS like in previous incarnations of WIN OS's - its purely a console for NT.
    Solutions:
    Emulator of some sort.
    Dual boot ( makeing sure that the partion / drive you want to put this on is a compatable File system ... ie not NTFS ) - make sure its also not on an SATA Hard drive etc ... as that will probably not be accessable to DOS ( don't quote me on it though )
    Make a boot floppy / boot cd for DOS and have one partion on your hard drive set up as MS DOS so you can store all the game binaries on it and run the OS from the floppy / CD.
  5. Squiffy
    Squiffy
    May 23, 2002
    11,647
    Ashford, Kent
    +5,000
  6. Mr.The.Spoon
    Mr.The.Spoon
    Jun 12, 2003
    524
    I'm a Londoner.
    +13
    Thanks for all the help. I'll be trying them soon. Unfortunately I've other computer problems right now. Just changed motherboards and am trying to solve a graphics card / sound card conflict that makes the WarHammer40K demo crash after 3-4mins of play.
    You would not believe the number of times I've played the same 3-4 mins as I try out different drivers and configurations.
