I want a cheap RC that can be programmed...
Discussion in 'Home Cinema Control & Remote Controls' started by RichKS, May 6, 2005.
  1. RichKS
    RichKS
    Apr 25, 2005
    506
    Southampton
    +38
    Basically I want one that will work with all my kit, must be the "learning" type. I used to have a Cambridge Audio M1, but didn't really get on with it that well because of the hopeless battery life and the fact that it used AAAs (rather than the more abundant AAs i have tons of).
    Must have decent up/down/left/right etc menu, aspect, etc. Needs to have a button labeled "Colour" or similar. Must work with my Epson projector and ideally an XBox as well as my PC remote. Everything else is pretty standard kit.
    I'm not really looking to spend a lot on this. Ideally less than £30, but we'll see...
