I want a big hard drive
400 GB Hard Disk
Up To 709 Hrs HDD Recording
SD Card and PC Card Slots
Copy From DVD-R To Hard Disk
Ethernet Campatibility
5.1 Channel Output
DIGA DVD Recorder with 400GB Hard Disk - Available October 2004
What Video & Widescreen Entertainment Awards 2005 - Winner
"The DMR-E500HEBS is nothing less than a home cinema behometh....It's mouth watering stuff and this deck backs up that incredible spec sheet with superlative performance."
Its Never Been Simpler To Create Your Own DVD's;The DMRE50HEBS Has The Worlds Longest Recording Time Enabling You to Record Your Favourite Programmes And Easily Access Or Edit Them; Archive Home Movies On A Durable, High Quality Format ; Transfer Your Video, Audio, And Data From DVD Onto An SD Card For Pocket Portability.
Playable Discs
DVD-RAM: 12cm (4.7GB/9.4GB), 8cm (2.8GB), 12cm (4.7GB) (Ver.2.1 / 3x speed DVD-RAM Revision 1.0) DVD-RW, DVD-R: 12cm (4.7GB), 8cm (1.4GB) (for General Ver. 2.0), 12cm (4.7GB) (for General Ver.2.0 / 4x speed DVD-R Revision 1.0), DVD-Video, DVD-Audio, Video CD, CD-Audio (CD-DA), CD-R/RW (MP3, CD-DA, Video CD formatted disc)
Recordable Discs
DVD-RAM: 12cm (4.7GB/9.4GB), 8cm (2.8GB), 12cm (4.7GB) (Ver.2.1 / 3x speed DVD-RAM Revision 1.0) DVD-R: 12cm (4.7GB), 8cm (1.4GB) (for General Ver. 2.0), 12cm (4.7GB) (for General Ver.2.0 / 4x speed DVD-R Revision 1.0)
Recording Standards
DVD Video Recording Format (DVD-RAM), DVD Video Format (DVD-R)
Built-in Hard Disk Capacity
400GB
Recording Time
XP Mode
Approx. 89 hours (with built-in hard disc), Approx. 1 hour (with 4.7GB disc)
SP Mode
Approx. 177 hours (with built-in hard disc), Approx. 2 hours (with 4.7GB disc)
LP Mode
Approx. 355 hours (with built-in hard disc), Approx. 4 hours (with 4.7GB disc)
EP Mode
Approx. 532 hours (with built-in hard disc), Approx. 8 hours (with 4.7GB disc)
Television System
Tuner System
PAL-l
Channel Coverage
UHF: CH 21-68
Video
Video System
PAL colour signal, 625 lines, 50 fields / NTSC colour signal, 525 lines, 60 fields
Recording System
MPEG2 (Hybrid VBR) MPEG4 (VBR)
Input - Video In
AV1 / AV2 (21 pin), AV3 / AV4 (pin jack)
Input - S-Video Out
AV2 (21 pin), AV3 / AV4 (S terminal)
Input - RGB In
AV2 (21 pin) (PAL)
Output - Video Out
AV1 / AV2 (21 pin), Video out (pin jack)
Output - S-Video Out
AV1 (21 pin), S-Video out (S terminal)
Output - RGB Out
AV1 (21 pin) (PAL)
Component Video Output
Y: 1.0 Vp-p; 75 ohm, PB: 0.7 Vp-p; 75 ohm, PR: 0.7 Vp-p; 75 ohm
Audio
Recording System
Dolby Digital 2ch, Linear PCM (xp mode, 2ch), G.726(MPEG4)
Input - Audio In
Output - Audio Out
AV1 / AV2 (21 pin), Audio out (pin jack)
Output - Digital Audio Out
Optical terminal (PCM, Dolby Digital, DTS, MPEG)
SD/PC Card Slot
Card Slot
SD Memory Card Slot: 1pc, PC Card Slot (Type II): 1pc
Image File - Compatible Media
SD Card Slot: SD Memory Card, MultiMediaCard
PC Card Slot: A PC Card adaptor conforming to PC Card Standards, ATA Flash PC Card, PC Card Adaptor (SD Memory Card, xD Picture Card, Microdrive, MUltiMediaCard, Compact Flash, Smart Media, Memory Stick), Mobile hard disk
Image File - Image File Format
JPEG conforming DCF (Design rule for Camera File System), (Sub sampling; 4:2:2 or4:2:0) TIFF (Uncompressed RGB chunky) / DPOF Compatible
Image File - Number of Pixels
34 x 34 to 6144 x 4096
General
Power Supply
AC220 - 240V, 50Hz
Power Consumption
48W
Dimensions (W x H x D)
430 x 79 x 302mm
Weight
5.0kg
Acoustic Energy Corinium Speaker Review: A Stunner in Green!
Back
