I want a 50 inch 1080p screen
Discussion in 'LCD & LED LCD TVs Forum' started by jjasonuk, Apr 29, 2007.
Tags:
  1. jjasonuk
    jjasonuk
    With definately no speakers on it (want 1080p as sofa is about 8-10ft away from screen) also want it to be decent / excellent with SD imput and PS3.
    Not asking for a lot am I? lol
    Was looking a the Pioneer 507 Plasma but its not 1080p but is really really good with SD input.
    I will be using Virgin+ box (HD ready) and PS3 Blueray as inputs & I have my own Yamaha AMP.
    Any Idea's fella's? Stick to the 507 and forget 1080? May have to with a budget of £1500-2000.
  2. kayzee
    kayzee
    Feb 19, 2007
    1,087
    Essex
    +100
    forget 1080 imo... are there plasmas with 1080 around? only ones i know of are the sony W and X range and the F71 (and replacement whatever that is) which only go upto 46". oh and that aldi thing!
  3. Tek70
    Tek70
    Mar 29, 2006
    1,035
    +41
    How about 46" ?
    If this meets your requirements then go for this :http://www.loewe-uk.com/individual_compose_46_de,39275,53.html
    You get an internal hard disk capable of recording High Definition.
    You get an HD ready satellite tuner that can receive the free-to air BBC HD transmissions.
    Build quality is second to none.
    PIP & dual tuners twin HDMI.
    Price might be a hurdle but if you want one then prince will not stop you ! :D
  4. doubleup_dan
    doubleup_dan
    Apr 7, 2007
    39
    to be honest the plasma will be better for SD
    a good TV is the M87 they have a 52" model which is around £2100 but SD will not Excellent just ok
    but the 1080p on it for the PS3 will be awesome
    Edit:- the speakers are hidden too
  5. Lannie
    Lannie
    Mar 10, 2006
    14
    I am looking for a replacement for my Pioneer 506FDE as well. I want a 50" screen, for Sky HD and a media centre PC. Money is not a consideration: 1080p or a good image processor?
  6. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    Well the new Panasonic PZ700 is a 1080p plasma (due out soon) and within your budget if you shop around.
    I have no doubt it will be a fantastic set.
  7. doubleup_dan
    doubleup_dan
    Apr 7, 2007
    39
    do you know roughly when that set will be out ?
  8. B-real
    B-real
    Oct 26, 2006
    96
    +14
