I used to be able to do this...please help...Panasonic DVD Recorder
alfajerry
Hi guys,
I am trying to transfer some VHS to my HD recorder and then burn DVDs from the files.
VHS is Panasonic NV-HD630, DVD recorder is Panasonic DMR-EX77.
The problem is that the sound is very bad.
I have used these items to do this in the past but don't know what I'm doing wrong.
If I take the SCART direct from NV to TV the sound is OK.
Thanks,
Jerry
Derek S-H
Hello Jerry
When you say the sound is "bad", what do you mean exactly?
Muffled? Distorted?
I have a digital camcorder which I can record footage onto, and this was connected to my Blu-Ray recorder via the leads in your first image into a Scart adapter. I also transferred my footage to the BR recorder's hard drive first, then burned onto SD DVD, and both sound and picture were fine.
Are there any more connections under the front flap of your DVD recorder? Maybe it might work better that way? Perhaps you're using the wrong Scart connection on your VCR?
alfajerry
Sound is quiet AND distorted.
Connected as per the manuals.
Have tried three SCART leads.
No problem when SCART is direct from VHS to TV.
Derek S-H
Front flap inputs.
Okay, since there seems to be some sort of issue using Scart to Scart, have you tried something like this instead:
Amazon product
I notice you have Composite connections on both the front and back of your DVD recorder. Don't ask me why the Scart to Scart isn't working (there's probably some technical reason that's way beyond my knowledge base), but I think an alternative is Composite to Scart.
You might see and hear a drop in quality compared to the usual Scart to Scart, but there's no harm in trying. It might actually work!
JayCee
@Gavtech has often posted here about a particular IC (chip) on Panasonic DVDRs causing sound symptoms like you’re experiencing.
Don't waste your time ordering new leads.
Gavtech
Administrator
Thanks for the suggestion, Derek.
JayCee, I'll look at his posts.
There are quite a lot of posts involved - but if you use 'IC3001' as your search term, it should point you to a lot of relevant threads.
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
