i pod volume
Discussion in 'Headphones, Earphones & Portable Music' started by gino555, Feb 5, 2009.
  1. gino555
    gino555
    Mar 27, 2005
    411
    +7
    hi
    I have a 80gig i pod but the volume dont seem that loud i have the volume turned up full, i tried a ipod shuffle and that seems louder than the classic, has any one else had the same problem??
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
  3. gino555
    gino555
    Mar 27, 2005
    411
    +7
    does this work on pc's as well as macs?
  4. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    it works on ipod, regardless it is an app stored on the ipod
  5. swayne
    swayne
    Dec 30, 2008
    129
    Milton Keynes
    +11
    Have you gone into Settings and checked your volume limit?
    Steven.
  6. gino555
    gino555
    Mar 27, 2005
    411
    +7
    yeah up to the max!!!
  7. Zaichik
    Zaichik
    Mar 5, 2002
    1,622
    116
    +702
    I'm having the reverse problem with my iPod Touch - sometimes when I plug my earphones in, the volume is fine, other times it's far too loud, even on the very lowest setting. Think I might have a dodgy headphone socket.
  8. HugoFJH
    HugoFJH
    Jan 3, 2007
    2,346
    63
    London
    +133
    cant see how you can get it onto an ipod without going thru a mac or pc first - so Im not convinced that will work on ipod's connected to pc's
  9. bianco
    bianco
    Apr 3, 2008
    205
    +15
    Be careful, got mysekf a nice case of tinnitus by having volume too loud, make sure your just not drowning out background noise.
    If you are try getting some sound isolating earphones and you'll be happy with lower volumes.
