i-pod car install
ledzep100
Hi Guys,
Got myself an i-pod and I'm trying to install it onto my car by connecting it to the multi-changer phono input with a mini-jack to phono cable.
The sony MD headunit only activates the CD input when it's connected to the multichanger via the control cable.
The problem is that my sony multichanger wont load discs properly. When I connect the control cable to the multichanger and connect the output of the pod to the CD phono input and select CD I can hear the pod while the changer is trying to load a disc (sounds good). But as soon as its been through all the discs it errors and switches off the headunit.
Does anyone know if there's a way of getting this working without buying a new CD changer?
I'm thinking that maybe I can fool the headunit into thinking its attached to changer. I know you can get loop back cables for Alpine headunits but cant find them for sony's.
Any ideas?
ledzep
ledzep100
Thanks for that cwick,
It looks good, I really like the idea of having control over the pod. But for about the same money I could buy a new changer and put in a switch allowing me to listen to the changer when I never had the pod with me.
I think I'll contact them to see if the control will work with my headunit as that may be the deciding factor.
ledzep
rags
Ledzep - why dont you buy an i-trip mate ? No wires required and works on any FM radio with clarity.
ledzep100
Hi Rags,
I've now got an i-trip but in the M4 corridor it's a nightmare. You can tune too a frequency before you set off, but you get about a mile down the road before you get treated to some "urban jungle" pirates (booyaca sha!)
Even if this wasn't the case the fidelity is a bit lacking.
ledzep
Podcast: Philips OLED+935 impressions, Denon AVC110 Review, Film Reviews, News and More...
