I/P setting 32GA3
richjthorpe
Hi all,
I've come across this setting on my TV which switches the signal between Interlace and Progressive.
Am I right in thinking that even though I am feeding the TV with an RGB signal via Scart from my DVD player that the TV converts it to Progressive when the I/P is set ? The picture certainly doesn't flicker when I turn on the Progressive setting.
How does this Progressive setting compare to a dedicated DVD that kicks out Prog Scan via component ?
Thanks,
Richie.
jgrg
richjthorpe said:
Hi all,
Yes, it does convert it to progressive. RGB scart is always interlaced. But I always have my Sharp Aquos (which is what you have, right?) set to "interlaced" because I find that the progressive setting removes too much information from the signal. I think it scales up each video field (ie: just the odd or just the even lines) to the full frame - so it looks like a lower resolution signal.
If I'm watching a film, the I set the "movie" setting (also under the advanced settings). This usually gives a superb picture.
Progressive scan DVD players automatically detect whether the original is film or video based, and use different de-interlacing algorithms accordingly. De-interlacing film will perfectly recover the oringinal non-interlaced frames. Some of the deinterlacing chips (like the Faroudja ones) will also give a slightly better result when de-interlacing video beacuse they use much more sophistated algorithms. So when watching TV via RGB scart I take on the automatic detection role myself, and switch the Sharp between "interlaced" and "movie".
This is a great page to find out more than you ever wanted to know about de-interlacing:
http://www.hometheaterhifi.com/volume_7_4/dvd-benchmark-part-5-progressive-10-2000.html
James
