I no nothing about them, is this one any good?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by GalacticaActual, Jul 15, 2005.
  1. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    bump :)
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    By the looks of it the camcorder you linked to looks fairly good for £200, but IMO you will get a smaller and probably better cam if you get a DV camcorder.
    Digital8 uses larger 8mm tapes, where DV uses smaller 4mm tapes which in turn mean the camcorder can be a lot smaller and therefore more likely to get carried around. D8 is a Sony format, but I believe Samsung also make them. If you look at DV you will have a lot more choice from several different makes.
    I suggest you have a play with a few different models in a shop, then get on the net and find the best price. If you then go to a Jessops they will do an internet pricematch on any UK web site. Therefore if you have any problems you have a shop you can go back to, rather than a faceless internet site!
    Mark.
  4. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,858
    Galactica C.I.C.
    +279
    Thanks mark will try that. :smashin:
