I needa PC and TV total budget about £1600, ideas please?
E
ElizaMay
Reading some of the entries on this forum Iwonder if I would be best getting a PC and a separate TV or a Home Entertainment System centred around the PC. We don't often need PC and main TV at the same time. However our living room is fairly large so a little 15 or even 17 in screen would look a bit lost without using binoculars.
All advice and suggestions much appreciated.
supersonic87
I've gone for the second route and am going to build a PC and use a jvc HV28-P37, you can get the 32'' version for about £800 and if you can build a PC (Not to diffucult when you know how) £700 can buy you a decent PC, I'll hopefully be getting:
Athlon XP 2500+
Sapphire radeon 9600xt
2 X 256mb of pc3200 ram
80Gb hard-drive with 8mb cache
videologic 5.1 speakers (although you'll probably have a seperate system)
Asus A7N8X-E motherboard
A decent case (hopefully watercooled)
and all the other essentials
Without watercooling the PC, I got the total under £1300 at Ebuyer (including the TV, not at Ebuyer though :D) and with a 32'' screen it should be under £1500, and you can have a nice 32'' monitor :smoke: (using a ATI DVI-component cable), note the PC takes a high-def signal and you can use the PC at 1920x1080p.
You will however need access to the monitor to set the PC up (Mobo,etc, or so i've been told)
Rich
Podcast: Panasonic HX800 TV + Sony HT-G700 Soundbar reviews, movie and TV show news and reviews
