I need your help
Discussion in 'Nintendo Forums' started by geese, Jan 10, 2005.
  1. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    Hi all
    I have just bought a panasonic pd50 and have owned a pal gamecube since 2001 so it has a digital av output.........I was wondering if a component cable would be superior than my nintendo RGB cable( picture quality)?
    Will it be true 480p or.......
    thanx in advance
  2. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    comeon man..........somebody must know something about this.
    any help is appreciated
  3. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    Land of the Living, Essex
    +35
    It will be a small improvement over RGB, you'll only get progressive scan by running games that support, currently no PAL games support Progressive so you'll have to import the games.
  4. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    thanx CrispyXUK..................but I thought rogue leader2 and3 supported proscan along with some others? Will that mean I cant play resident evil4( pal) in proscan?
  5. Pooon
    Pooon
    Dec 26, 2002
    7,344
    Canterbury, Kent
    +935
    I think the safest thing to do would be to get a freeloader disc and a NTSC copy of Resi 4, progressive scan guaranteed.
  6. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    allright then, I wiil give that a shot...........but is there any noticible differences between pal 60hz an proscan?......BTW thanx
  7. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,737
    71
    +35
    depends what display you are using
  8. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    panasonic 32pd50.
  9. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    Its not HDtv.........but has super resolution picture.
  10. m4A1
    m4A1
    The difference is huge. I've been spoilt by prog scan, and hate playing interlaced signal games now >_< !
    The main obvious difference is there are no horizontal scan lines visible. This looks wicked! The picture appears slightly more detailed, alot cleaner, and sharper.
    That's just on 480p! GC games don't seem to have any Hi Def resolutions supported at this time, not that I'd be able to display them anyway. Trust me, your missing out.
  11. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    proscan is the best way then.............I just need that damn freeloader.
    thanx for your help people
  12. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    34,839
    Bristol
    +8,180
    You can get Freeloader for £9.98 from Game, actually its Action Replay but it has Freeloader built into and at that price its a bargain as most other places want £18+
  13. geese
    geese
    Sep 13, 2004
    747
    28
    +37
    I´ll do that..........thanx for the advice.
