I need your advice again guys...bi-polar?
Discussion in 'Home Cinema Speakers' started by Debs67, Apr 20, 2005.
  1. Debs67
    Debs67
    I want to add some new surrounds to my set up.
    I have Diamond 9.5 fronts,9CM centre,Yamaha YST-SW215 sub and Diamond 4 rears! :rotfl:
    I want to add 2 rears,should I go with a set of bi-pole 9DFS or a set of the "normal" bookshelves in the 9 series? :confused:
    I have a small room with the sofa against the wall and they would be mounted just below ceiling level.Plus the TV and fronts are in the corner of the room and a true even surround placement is not possible!
    Any thoughts!?
    Debs ;)
  2. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    692
    43
    +140
  3. Debs67
    Debs67
    Yes,I think I agree,I'll probably go for the 9.1's,thanks again!
    Debs
