I need to make a choice between these...
Discussion in 'LCD & LED LCD TVs Forum' started by Lentrica, Sep 19, 2007.
Tags:
  1. Lentrica
    Lentrica
    Since I have to exchange my broken one for a replacement, I've got these choices to choose from... which one would you recommend?
    Sharp 42" - LC 42XD1E - £880
    Sharp 42" - LC 42SA1E - £1150
    Sharp 46" - LC46XD1E - £1124
    Sharp 46" - LC46XL1E (New Model) - £1464
    LG 42" - 42LY95 - £922
    JVC 40" - LT40DS7BJ - £1064
    JVC 42" - LT42DP8 - £988
    JVC 42" - LT42DV8 (New Model) - £1116
    JVC 46" - LT46DZ7 (5 year guarantee) - £1370
    LG 47" - 47LF66 - £1141
    LG 47" - 47LY95 - £1252
    Samsung 46" - LE46M87BD - £1192
    Samsung 46" - LE46N87BDX - £1370
    Sony 40" - 40X2000 - £1530
    I'm guessing that Sony is the best make but does any of the others in this list beat the Sony in any way?
    Unfortunately, this place doesn't offer any other makes so I have to choose from the above.
    Which would you recommend I buy? I'm looking for the best quality and features.
    Thanks,
    JH
  2. Aaron Mc
    Aaron Mc
    Apr 22, 2007
    116
    +8
    there is no such thing as a 42" X series Sony you [Circumventing the swear filter - read the forum rules - edited by Curly99] liar
  3. Lentrica
    Lentrica
    Edited.
  4. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
  5. Lentrica
    Lentrica
    Unfortunately, the store I have to use is charging £1530 for it. I have to get my replacement from them and I'm covered up to £1450. Everything over that is on me.
    So how does the Sharp 46" compare to the Sony?
    JH
  6. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    Both excellent.But I think the sharp has an advantage because of the 100Hz and the bigger size.Your only concern is banding
  7. Lentrica
    Lentrica
    Thanks. Sorry to be a pain but what is Banding?
    JH
  8. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    Banding is an isue that has been visible on most sharp lcd's.These are vertical or horizontal lines crossing the screen while viewing
  9. Lentrica
    Lentrica
    Do you think Banding is a reason for return under warranty?
    Can I return it if it happens?
    JH
  10. Lentrica
    Lentrica
    JH
  11. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    Yep you can demand a replacement
  12. Lentrica
    Lentrica
    Ok Thanks, I think I'll go for the sharp then.
    JH
