I need to get an ok priced, feature full DVD player for my parents...
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kurak, Dec 18, 2003.
  1. Kurak
    Kurak
    They don't really want anything "uber" but a few keys are progressive scan, component video, and the ability to play a wide range of media. Also, do most DVD players play VCD and SVCD? (This is actually something I was interested in)
    It should have good reviews also. Normally I'd do more research, but I saw this site mentioned on tech tv and I needed help quickly. Thanks ;)
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Budget???Location?
    If UK then HK DVD 25 or Marantz DV4300 if budget over £200 if less then RS stores or aldi!
  3. Kurak
    Kurak
    This is in the US....
    Budget is probably 200 USD max.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try over at AVSforums as this is a UK site mate!
  5. Garrett
    Garrett
    Apr 21, 2001
    31,485
    2
    The best thief you’ll never see.
    +4,045
    Try getting hold of the American equivalent of our Pioneer 565 it should be cheaper over there than here and will handle most anything you can throw at it.
