I need to choose. A long scart to tv or long interconnect to audio?
Discussion in 'Cables & Switches' started by sponnie, Mar 15, 2006.
  1. sponnie
    sponnie
    Jul 3, 2005
    78
    I have just been informed the the Cambridge Audio DVD89 is not available in black in the UK so I don't really want to put a silver one in amongst my black hi-fi stuff. I wouldn't mind putting it under the tv but that is 3 metres away from the amp.
    I was going to use a 3 metre scart from the hi-fi rack to the tv because I'm more interested in quality audio rather than picture at the moment. I don't have a super dooper tv yet.
    Would it make much difference to the audio sound if I have a 3 metre interconnect?
    Thanks for any advice :)
  2. jackal
    jackal
    Fibre Optic (Toslink) digital link is your best bet (not affected by distance)
  3. sponnie
    sponnie
    Jul 3, 2005
    78
    Thanks for replying but my amp is totally analogue :(
  4. paulflowe
    paulflowe
    Don't be concerned by the 3M distance A good cable will not deteriorate at this distance (or even triple it...) It'll be helpful if you supply the make/model of the TV and amp for more assistance from the forum regulars.
    Paul. :thumbsup:
  5. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    3m isn't a long way.
    If I'm worried about sending video, it's more than 50m (VGA / composite safety zone)
    If I'm worried about sending audio, it's 30m for unbalanced and 100m for balanced I start to panic - just buy decent interconnects (audio is the cheapest option as adding extra metres to scarts tends to cost £££)
  6. sponnie
    sponnie
    Jul 3, 2005
    78
    Hi there guys and thanks for replying.
    My amp is a Pioneer Precision.
    The tv is just an old Goodmans basic CRT. I'll probably relace it later this year. It does fine for me at the moment.
    I was thinking of buying some quality cable from Maplins. The Pro Audio stuff at 3.49 a metre and soldering some phono connectors to it.
    I think that would work out at about £30. I can buy a half decent 3 metre scart IXOS XFT02-300 for £20 but as I said I'm more interested in audio.
    From what you say it sounds like it won't affect the sound at all either way so that is good.
    I just wish Richer Sounds sold the DVD89 in black! I mean they are the sole stockists in the UK so why wouldn't they sell that one?
  7. baldrick
    baldrick
    Dec 28, 2002
    3,370
    Providence, Rhode Island
    +246
    Traditionally Richer Sounds used to sell off old models etc... so if they only sell what they can get and if they can only get silver.....
    I don't know if that has changed or not?
