joeyramone
Hi guy's, I want to be able to connect an acer aspire 5720 laptop to my hd tv. I am aware that the laptop only has a vga out (the tv also has a vga port) but as you know there would be no sound unless you have a 3.5 jack cable. I have a hdmi to dvi converter adapter but then i'd need to get an dvi to vga wire. The question is though, am i wasting my time as the final piece of kit going into the laptop would still be vga and that does not transmit the audio element, or would it? Is there a pice of kit out there that would do everything i want? This all started when my daughter, who has the small box room, and i mean small said she had nowhere to work on her laptop. I thought i would hook it up to the tv and get her a wireless keypad with the built in tracker ball.
Before anyone suggests spending loads on a new laptop I would if i could but just not at the mo.
joey
joey
