i need this
swanytroon
im looking for a amplifier and receiver in 1 if there is such a thing
i want to connect a cd player with 2 speaker setup an my dvd player with the 5.1 setup
is there anything u can show me to do this if not what is there like this
also the cheaper the better
Daneel
You only have a choice of maybe 1000 units? :)
If you want something cheap check out the classified ads.
BTW: AV amp = no radio, AV receiver = built in radio
I put AV in there since you mentioned DVD.
Daneel
Define low cost. £200 receivers can be had from the likes of Marantz and Yamaha.
swanytroon
yeah between 100-200 im on a tight budget an just looking for a simple setup so any model which would be good for me
Dfour
Marantz
http://www.richersounds.sv01.net/index.php?f=itemdetl.php&p=301738
Yamaha
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1437
Sony
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1434
A little over your budget but loads people rave about them.
Denon
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1605
Pioneer
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/1505
It is best to buy a known brand and one that is as recent as possible so that the dreaded disease 'upgraditis' takes more time to settle in.
Hope this Helps :)
Sony A90J & A80J OLED and X90J & X95J BRAVIA XR TV Line-up & Features: Sony Interview
