i need some isolation
Discussion in 'Headphones, Earphones & Portable Music' started by mcbunny, Jun 15, 2009.
  1. mcbunny
    mcbunny
    Sep 6, 2005
    579
    York
    +21
    i have some e2c's at the moment and the last time i used them on a flight they were ok but i could still hear alot of noise when i wasnt listening to anything.
    i would like something that provides better isolation dont want to spend a fortune so say £50 and the aim is isolation over sound quality
    Mike
  2. mcbunny
    mcbunny
    Sep 6, 2005
    579
    York
    +21
    anyone ?
  3. ZootHornRollo
    ZootHornRollo
    Apr 6, 2007
    122
    +4
    how about these?
    [​IMG]
    :D
  4. mcbunny
    mcbunny
    Sep 6, 2005
    579
    York
    +21
    hehe not a bad start but i cant plug them into the plane ;)
  5. r@mside
    [email protected]
    May 29, 2006
    254
    28
    +25
    Have you exhausted all of the options for suitable tips?
    Foam tips are good for extra isolation because they squeeze into your ear canal and then expand for a close fit. Shure offer foam tips that receive a lot of praise for isolation, durability and comfort.
  6. mcbunny
    mcbunny
    Sep 6, 2005
    579
    York
    +21
    i used the orange foam ones that they came with i didnt know you could get different tips for them :(
    is there any ones that i should be especially looking at ?
  7. philaitman
    philaitman
    Oct 17, 2006
    920
    43
    +159
  8. mcbunny
    mcbunny
    Sep 6, 2005
    579
    York
    +21
    oh brill will give these a go and get the wife to shout at me(she will most probably already be doing that anyway) to test them out
