I need some help with an Onkyo hardware mod
vvv
My brother-in-law recently returned to the UK after living in the USA for some years. He brought back with him two fully functional US spec 120V 60hz Onkyo TX-SR705 AV Receivers.
Sadly, he dumped one at the council tip after not being able to get it to work with a Maplin's transformer. The other one he fortunately gave to me after he bought a UK spec Onkyo to replace it.
I have been happily using my TX-SR705 with the 3.3Kva 110v 50Hz site transformer that I use with my electric cement mixer. I put a yellow 16A plug on it and the Onkyo sounds great. My wife doesn't like the yellow site transformer in the living room which is the main reason why I would like to modify it. Now that I know that this receiver has no problem working on 50Hz AC, I would like to modify it permanently to work on 240V 50Hz mains.
The Onkyo has a large 'HCPS' transformer inside for the amplifier and a smaller transformer that powers the control electronics. Does the HCPS have tappings for 240V? If so, do I also need to replace the smaller transformer for a similar 240V equivalent?
If I can't get the Onkyo to work directly on 240v 50Hz I will just get my electrician to install a yellow 110V socket in the house that is connected to a site transformer outside.
"If I can't get the Onkyo to work directly on 240v 50Hz I will just get my electrician to install a yellow 110V socket in the house that is connected to a site transformer outside."
All that for one amp? Converting that Onkyo to UK spec will cost a bit, so will a 110v socket.
I'd sell it.
vvv
I've already got spare 110v sockets, cable and a transformer but I was hoping that someone would be able to tell me if the HCPS is dual voltage and that it would just need resoldering on different terminals.
The only thing I need to buy so far is some plastic trunking for the rear speakers. I had a spare set of 6 Ohm speakers from an old Aiwa 5.1 system and some 6 Ohm Hi+Low Technics speakers that I've setup as bi-amped. I haven't spent anything on it yet.
Chuffy2
VVV, did you ever get anywhere with this? I am about to move back to the UK and am planning on taking my Onkyo TX-NR616 back with me. It is also 110v 60hz. I have a 1000w stepdown transformer back in the UK that I was planning on using it with, but was wondering if there was another way to avoid having the transformer laying around as well. Thanks.
vvv
Onkyo refused to help and I never went any further with modifying it because it works so well with the 3.3Kva builder's transformer. I don't have the transformer powered up all the time. I only switch it on when I use the Onkyo. It's been working well like that for two and a half years.
Similar threads
