i need some advice on a system??
Discussion in 'Hi-Fi Stereo Systems & Separates' started by haven't-a-clue, Oct 2, 2004.
  1. haven't-a-clue
    haven't-a-clue
    i'm thinking of getting a new home cinema but i'm not sure if will all match. maybe ye hi-fi fans can give me some advice!
    will the new pioneer VSA-AX10Ai-S match with the B&W CM series???
    also i thinking of gettinga 50" pioneer or panasonic plasma, any idea which would compliment the above two???
    again which DVD player/recorder would suit to all of this????
    thanks for your help!
  2. Striki
    Striki
    the Ax-10i will suit those speakers. With this amplifier i would choose the pio 868avi dvd player for the i-link to the amp. And for the plasma, the pioneer to, because you could link it to the dvd player using hdmi. hope it helps.
