I Need .............. Please
Discussion in 'General TV Discussions Forum' started by kourosh, Mar 8, 2005.
  1. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    ive decided to connect my pc to my tosh for high def movies but my pc dosent have a suitable graphics card im not to sure what to go for ive looked at a couple but dont have a clue :confused: ati radeon 9600,ge force fx5200,or a radeon 9250.does it have to be a 256mb or a 128mb will do or if any 1 has any other sugestions on other cards please tell me(i only want to spend about £100 ish maybe a little more and also is there any special software i need to run the movies or demo's thanks for your time :hiya: :thumbsup:
  2. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    You can get an ATI Radeon 9550 with a DVI out for approx £35 you will need a DVI cable & a DVI to HDMI adaptor.Whatever you get try & get a card with DVI the picture quality is so much better.
    If you want to get a better card i sugest a Radeon 9800 pro or a Nvidia 6600GT but a
    9550 should be fine for most people.
  3. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    is that the 128mb version or the 256mb version? does it matter anyway thanks :thumbsup:
  4. schnipps
    schnipps
    Jan 6, 2005
    117
    16
    The amount of ram wont matter atall Kourosh, not for dvd playback, thats more to do with textures in games etc
  5. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    thanks schnipps :smashin: so would any cheap card be ok just as long as it has dvi out? :thumbsup:
  6. St_ve
    St_ve
    Jan 6, 2005
    1,059
    39
    Birmingham
    You could try one of the ATI all in wonder cards with the tv tuner aboard i don't know how they compare with my PCI tv card.
    Prob any card with DVI would be fine however it would be worth getting at least a radeon 9200 they were around £30 2 months ago.
    a VGA card will give you a good picture just not a great one
  7. kourosh
    kourosh
    Feb 6, 2005
    14,966
    Portsmouth
    +1,124
    thanks when i get home from work i will have a look about on the net and choose 1 :thumbsup:
