I need persuading?
Discussion in 'Blu-ray & DVD Players & Recorders' started by spocktra, Dec 3, 2004.
  1. spocktra
    spocktra
    Nov 22, 2004
    2,048
    48
    worcester
    +40
    After reading all the good reviews on the toshiba sd340e i thought i would invest.However i did the same with a 32pd30 and was not impressed[since swapped for a tosh].I was hoping to get a bit of advice here as most people on these forums dont use reference quality components hence more realistic opinions.I want to spend around £80-£140.Thanks for ANY advice.
