I need new rear speakers
alcarmichael
I have just fried one of my rear speakers so looking for a recommendation from you lovely people on what to replace them with. I have large mains, one (soon to be two) BK Double Gem’s, running off an Anthem MRX310 with the main speakers using a separate power amp. The rears will be about 10’ either side of the seating position.
Looking to buy used to keep the budget down.
They’ll be replacing B&W DM600 s3’s.
password1
What are your front speakers? Do you want them to match the front speakers aesthetically?
Any budget or aesthetic or size constraints?
alcarmichael
I didn’t state my front speakers as very few will be aware of them:
Reiver Acoustic, Edingdale GT.
Budget would be sub £400.
Size not too much larger than the DM600’s if I can get away with it.
Aesthetically they just need to be acceptable to the missus.
Mr Wolf
If you liked the DM600 S3, the successor B&W models were 686, 686 S2 and 607. All have 5.25” drivers so similar size to the 600 S3. Always plenty of 686 models available on eBay for under £200.
alcarmichael
The DM600’s came about because my fronts also used to be B&W speakers. Nothing wrong with them but now I am more open to any brands I thought I may be able to do better. I would like the rears to provide more sound coverage if that makes sense? Less localised.
password1
How about some Dipole or bipole that have 2 tweeters spreading out the sound rather than bookshelves?
I doubt replacing pair of B&W bookshelves with another pair will give you wider dispersion.
alcarmichael
I had considered this option already but have never heard any… I’ve read that they can be quite marmite.
Gasp3621
If you can mount them little bit out from corners (1-2feet) then example MA Silver FX normally 499£, now 299£ ex-display model. 147mm depth, flush against wall with two keyholes at back for screw mounting.
img_2646-jpg.852552
alcarmichael
The FX look like a good option but it’s made me realise I wasn’t specific enough in my initial post - The room is recently decorated, current speakers are on stands. I won’t be chasing wires into walls so I don’t think wall mounted speakers can be an option….
alcarmichael
Yeh, but that's great if you love Marmite - I do! (Marmite not diploles).
There’s something wrong with your tastebuds!
password1
No need to chase cables or drill holes on walls.
Just make a tall wall leaning stand.
I have a 9.1 system in my lounge (including 2 front height speakers) with a heavy 2.4m motorised screen and projector mounted a foot away from the ceiling.. all mounted on wall leaning stands with no chasing or a single hole drilled on any wall.
alcarmichael
Do you have any pictures of these stands please?
