I need more scart-inputs on my telly. Any solutions?
Discussion in 'General TV Discussions Forum' started by arnthelene, Dec 16, 2002.
  1. arnthelene
    arnthelene
    Hello!
    I have a Philips 32" Widescreen TV. It has two scart contacts and one composite. Both scarts take RGB. One of them S-VIDEO.
    I need tree scart contacts.
    Any solutions?
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,239
    Manchester
    +747
    Use a 2 to 1 SCART switch from B-Tech. Argos & others sell them.
    Mine is a BT22 and is both S-video & RGB compatible .
    I can switch either my DVD-player or my Digital satellite receiver (not a $ky one), both of which are set to give RGB output, into 1 of the RGB SCARTs on my Philips WSTV no problem at all ; FWIW I am using RGB1 on the TV.
    Chris Muriel, Manchester.
  3. arnthelene
    arnthelene
    Is the quality equally good with a 2 to 1 as with a standard scart?
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,239
    Manchester
    +747
    The quality is fine as long as you use decent-ish scart leads.
    Many forum members use the BTech switches & similar.
    Chris Muriel
