Question I need help with my Harmony Elite...where to ask?
Discussion in 'Home Cinema Buying & Building' started by Hooligaani, Oct 10, 2017.
Tags:
  1. Hooligaani
    Hooligaani
    Oct 10, 2006
    2,384
    116
    +955
    I'll copy/paste my post from the official harmony forums, although I think it's got some tumbleweed stuck in it.
    Can anyone here help?
    Harmony Elite sending different commands in activity.
    I have a watch TV activity that uses my LG TV, Netgem 7600 and Yamaha Amp. Everything turns on and seems to be working fine. If I press GUIDE whilst inside the activity I get INFO. If I select devices, select Netgem 7600 and then press guide I get the correct guide.
    This is really infuriating and I feel like I've been fighting with it for weeks.
  2. citywalker
    citywalker
    Mar 7, 2012
    801
    46
    +140
    Did you teach buttons from original remotes or just downloaded from internet?
  3. Hooligaani
    Hooligaani
    Oct 10, 2006
    2,384
    116
    +955
    Some have been taught from the original remote, the buttons work when I'm controlling a device individually. It's only when inside an activity that they go bonkers.
  4. awentford
    awentford
    Nov 18, 2016
    110
    london
    +22
    you can reassign what each button does for each activity, I think you need to plug it into a pc to do it.
  5. Hooligaani
    Hooligaani
    Oct 10, 2006
    2,384
    116
    +955
    I've done that, it doesn't change anything.
  6. citywalker
    citywalker
    Mar 7, 2012
    801
    46
    +140
    Sounds strange... can you assign some other function into that button and does this work?
  7. awentford
    awentford
    Nov 18, 2016
    110
    london
    +22
    did you definitely sync it after making the change?
  8. Hooligaani
    Hooligaani
    Oct 10, 2006
    2,384
    116
    +955
    Yes it's synced.
  9. awentford
    awentford
    Nov 18, 2016
    110
    london
    +22
    If you still haven't sorted it then give their customer services a call, they're supposed to be really helpful.
  10. Hooligaani
    Hooligaani
    Oct 10, 2006
    2,384
    116
    +955
    It looks like I sorted it, I pulled my Harmony One out of retirement to test with that. When I checked the configs I noticed that I had in the One the Netgem 7700 but in the Elite I had marked it as a 7600.
    Duuuuh! Thanks for the reply though :D
  11. awentford
    awentford
    Nov 18, 2016
    110
    london
    +22
    I had a similar problem with my BT vision box, amazing what difference/frustration a small change can make. Glad you got it sorted though.
