I'm looking at around £600ish for the whole setup and they should be available in black. I'm pretty much decided on the 1906 but what do you think of these two speakers.Badger0-0 said:Not as good as a plain stereo amp.
How fussy are you? is the question.
I could give you some cracking advice mate![]()
But do you have 20 grand spare??
Sorry.........., I'm not trying to be patronising, but it does help if you say how much your budget is![]()
Thanks..I'm checking them out now. The MS sub is bit priceuBadger0-0 said:The Kefs are highly rated, but I've never heard them.
I don't know anything about the Q acoustic, sorry.
Just had a look at your link.
Interesting, you will go bigger than titchy![]()
I'd move up a notch, personally, to bookshelves.
I keep pumping the SVS 5.1 setup, because I have it and it's excellent.
It runs out at more than £600, but can be had for a few quid more maybe![]()
That's that one out the way, come back if you're interested![]()
Otherwise, consider Mordaunt Short 9xx series with a 309 sub.
I used a pair of 902, a pair of 903 and a 905 centre, very nice too, for the money and the 309.
The rear 903's could be replaced with 902s, no problem.
Second hand, well now you're talking, the MS 904 and 906 floorstanders are very good and serious value for money.
Are we sucking diesel or am I on the wrong track???
I've got the SVS SBS 5.1 set-up, I'll post a link shortly.paulm187 said:Thanks..I'm checking them out now. The MS sub is bit priceuI've got no room for floor standing speakers in my lounge. What setup have you got with the SVS (models etc)?
Thanks for that!Badger0-0 said:Here you goGet on these
You'll be part of a small elite group, in that these haven't been recognised yet.
This is a bargain, IMO.
http://cgi.ebay.co.uk/SVS-SBS-01-5-...1QQihZ014QQcategoryZ14996QQrdZ1QQcmdZViewItem
The sub can come later![]()
The Denon AVR1906 is very very poor when it comes to stereo reproduction, it doesn't matter what speakers you stick on the end of it. If you have decided on that amp already then there is not much you can do about that.paulm187 said:I'm planning on getting a Denon 1906 for my home cinema. I will be connecting my HTPC to it. I am looking for good 5.1 surround sound speakers. I will also like to have good stereo for music. How is the Denon 1906 when it comes to stereo?
I havn't bought the Denon 1906 yet. What would you suggest is good for Stereo. Buy a seperate Stereo amp? If I do how do I go about hooking it up to the speakers? Would I need a seperate set of stereo speakers?Crustyloafer said:The Denon AVR1906 is very very poor when it comes to stereo reproduction, it doesn't matter what speakers you stick on the end of it. If you have decided on that amp already then there is not much you can do about that.
For £600 I would probably consider the Kef KHT2005.2 which are around that price.
