I need help conecting my Denon3802
Discussion in 'AV Receivers & Amplifiers' started by Ash007, Dec 30, 2001.
Tags:
  1. Ash007
    Ash007
    Dec 29, 2001
    217
    16
    Rochdale
    Ive just bought a Denon 3802. I'm not sure which cables I need. Firstly, the Receiver is about 5m from my TV,DVD and Sky+ box.
    To set up, the Receiver it needs connecting to the TV (5metres away) as all the setup options are displayed here,
    so,
    Do i just get a cheap SVideo lead just for the setup process (unpluging after I've set all the setting)
    Or
    Do I really need to have my Receiver permenantly connected to my TV (Maybe it will display the receiver volume or other stuff, I don't know). In this case I think I would have to attach my Skybox S-Video out to my Receiver and then connect the S-Video out on the Receiver to the Scart on the TV.
    This solution would require 2 * 5 meteres of S-Video lead. Would this degrade the signal or not?
    What appears on the TV screen when connected all the time, anything important/handy?
    Any help appreciated
    Thanks,
    Chris
  2. Doubledoom
    Doubledoom
    Various ways to connect depending on what you think is acceptable.
    option 1 - RGB for both DVD and digibox but need to record via the RF.
    Audio carried from TV to Amp and DVD to amp (TV passes audio from vcr and
    digibox)
    DVD > Digibox VCR scart ( use scart lead, set DVD to output RGB)
    Digibox > TV (use scart lead into RGB scart socket)
    Video > TV (scart lead into composite scart socket - Don't use an expensive cable, it would be wasted)
    Aerial > digibox > vcr > TV
    DVD > Amp (using digital co-ax or optical -identical quality, depends on your available connections)
    TV > Amp (using 2x phono connection)
    Option 2 - RGB for digibox and s-video for DVD. Allows recording via the scart. Audio the same as above
    DVD > TV (scart into s-video scart)
    Digibox > TV (scart into RGB scart)
    Digibox > VCR (composite scart - Don't use expensive cable for this one)
    Option 3 - TV doesn't pass audio or doesn't pass it with decent quality. Will require manual switching between sources. Use video connections as option 1 or 2.
    VCR > Amp (using 2x phono connection)
    Digibox > Amp (using 2x phono connection)
  3. Noman
    Noman
    "Do I really need to have my Receiver permenantly connected to my TV (Maybe it will display the receiver volume or other stuff, I don't know). "
    No, most settings can be done on the reciever (with info in the recievers display)
    For 1st time setup (small/large speakers etc) I think you have to connect it to the TV. Use "anything" that is 5 meters and connects to the composite output on the reciever.
