I need another Component connection!!!
I just realised something, I have a 360 via Component and the Wii will be 480p via Component...that means I need another component connection!
Or can you purchase a splitter?
fizzgog
im pretty sure that you can purchase a splitter - try maplins.
i only have one component input on my tv so i plan to run both the 360 and wii (when i get them) through my amp which has three and hope that i do not lose too much image quality.
hope that helps
pete
fizzgog
hornydragon said:
you need not worry, ou can get manual and autoswitches with 2-4 inputs easily
do you lose much image quality with these?
thanx
pete
Well what can you get which is good value for money and you don't lose any quality? Obviously I dont intend to have both the 360 and Wii on at the same time.
Cheers for the advice.
Epicurus
An expensive alternative is to buy yourself an amplifier with component in and out. Ive got the Yamaha DSP757AX which has 2 component ins, one component out, and several composite and s-video inputs which the amp upscales as best as possible through component.
Similar threads
