i need an amp
Discussion in 'AV Receivers & Amplifiers' started by masimo72, Jan 21, 2008.
  1. masimo72
    masimo72
    Dec 17, 2007
    2
    i wonder if any one can help i have a BOSE - ACOUSTIMASS 3 series II on the sub woofer they say 2 times 50 watts iec and nominal impedance 5 ohms i am wanting to buy a micro system and would like to know what power of amp i need to run these properly i have been looking at the Onkyo CR-715 DAB which is 50 watts per channel minimum into 4 Ù, 1 kHz, IEC this means nothing to me would this do the job or do i need something else thanks
  2. jensK
    jensK
    Dec 15, 2005
    414
    +41
    My friend you are in the speaker forum. It is better to post your question in the amplifier and integrated receiver section.
    Cheers.
    PS: as your system is only a two chanel system you have to ask yourself if you want to go all the mileage and get yourself a home cinema amplifier that can drive 5 or 7 speakers and a subwoofer.:D
  3. recruit
    recruit
    moved to the amp and receiver forum.
