i need advice
Rich
could someone please tell whats the difference between the panasonic plasmas TH-42PWD4 and TH-42PWD4b ?,i know the first is the commercial version,but what does that mean,can it be used for home use ?.......thanks in advance
S
steelej
Hi Richard,
Do a quick search, It's been covered before, this'll answer your question and then some :)
John.
sapper
There are times we should collaborate and produce an FAQ for the group
The problem with searches is trying to use suitable key words to get teh information you want with out too many 'dirty' hits.
Adrian
Rich
thanks steelej,that was a big help........sorry i'm new on here,next time i'll search the forums
S
steelej
No problem Richard, I'm fairly new here too, so you don't need to apologise :) I hope you didn't feel I wasn't being as helpful as I could have been with my postl, it's just that I didn't know the exact answer to your question but I knew I had seen it before, that's why I suggested the search. I just wanted to make that clear :)
John.
Rich
ive found the Panasonic 42WD4 BX for £2999(ive spent ages trying to get it below £3k),so i might have to go with that..................unless someone knows a cheaper supplier?????
sapper
Who is the supplier.
If it is the BX, it shouldnt need a bnc card as i understand, but as mentioned in another thread recently, make sure it is ready for 'plug and watch'!
A bargin isnt a bargin if youhave to hunt for soemthing else before you can watch it
Adrian
