I need a wireless surround sound system
Discussion in 'Home Cinema Buying & Building' started by magnole01, Oct 23, 2005.
  1. magnole01
    magnole01
    Im looking for a surround sound system with wireless rear speakers. i have a budget of £350 but cant seem to find what im looking for. Can anyone help
  2. daveande
    daveande
    Aug 29, 2005
    63
    Harrow on the Hill, Middx.
    How about the Sony DAV-DZ700FW, at £358.70?
  3. fathervic
    fathervic
    Jul 6, 2005
    285
    Scotland
    +18
    One of the systems to look at would be the Panasonic SCHT880W. It has a little receiver you place at the back. It's not a totally wireless system but a start of something that may fit the bill... The SRP may be above your budget but you can always shop around. Wireless technology is still not quite there yet for practicality/quality for HiFi and H/C applications (and I dare say cost for the manufacturers). There's still plenty of discrete cable around thats fairly easily hidden...
  4. DarrenB
    DarrenB
    The Sony Wireless soulution (SDIAT) uses a digital infra-red system which gives good, clear rear surround channel audio.
    Other manufacturers use FM which is most defianately inferior in audio quality.
    I have the DAV-700 and can confirm it works just as well as my JBL 5.1 wired speaker setup.
  5. chimpmagnet
    chimpmagnet
    May 26, 2005
    277
    +6
    Hi there,
    whats the difference between the DAV-700 and the DAV-500 ? Is it only the wireless functionality?
  6. DarrenB
    DarrenB
    the 700 has two digital inputs, to facilitiate connecting other dolby digital devices such as sky+, PS2, external dvd player and so on....
  7. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Hi - a few questions please, re; DZ700FW
    1. Would you say that the quality (wireless rears) would be un-noticable - I currently have a Sony HT-K250?
    2. How do you set up the rears? Did someone said it used infared?
    Thanks.
  8. Kopacabana
    Kopacabana
    Aug 18, 2005
    529
    +7
    The rears are indeed infra-red.
    There is a small transmitter, linked to the DVD player which has it's own little stand (it's quite 'cute' as it's tiny). It can be placed anywhere (has a very long lead allowing this).
    The receiver, linked to the base one of the rear speakers, is just as small and again can be placed nearly anywhere.
    The signal is very strong and seems to be able to negotiate table and chair legs.
  9. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Since it is a pain to get at the moment, I have found it for £350 delivered from www.bananamedia.at (based in Germnany).
    Never bought anything other than a DVD from overseas, if anyone has any advise or thoughts about doing this.
    Thanks.
