I need a wall shelf system, help me find one please.
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by gizlaroc, Jun 23, 2004.
  1. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    I am after a wall mount shelving system, like the ones you see in Hi-Fi stores, the ones where they have a bronze section the mounts to the wall and then you can add shelves to it, it also has the benifit of being able to route the cables through the bronze section.
    I want it to go under the plasma, hide my cables and also be able to hold my centre speaker, any ideas ????
  2. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,176
    Norwich
    +796
    Just the job, cheers
    £240 for a centre speaker shelf!!
    does look good though ;)
  4. noidea
    noidea
    Jun 8, 2004
    985
    46
    +123
  5. bobbypunk
    bobbypunk
    or try www.vogels.com
    the products you want are TVA2045 and TVA2046 (About £30-40 each)
    and TVA2041 (£6 each) to hide the cables!
