I need a wall mounted DVD player!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Judith, Dec 31, 2004.
  1. Judith
    Judith
    Since I am going to wall mount my LCD TV I would like to have a DVD player mounted below it. I have tried looking on the internet but have only found one that is part of a very expensive home cinema set up. Any suggestions?
  2. gandley
    gandley
    Aug 31, 2003
    5,024
    Paradise Lost
    +269
    SUPER GLUE :smashin:
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  4. Hifi addict
    Hifi addict
    try vogels mounts. They are made for that and not to expensive. www.vogels.com
  5. Judith
    Judith
    Very funny!!! But I think Vogels is a better suggestion.
  6. Judith
    Judith
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    cause to mount below you need room to put disc in etc which will make it look detached from TV (i used to work for a very lifestyle dealer and to the side worked better re cables etc)
