I need a single input/dual output Component Video Box
Discussion in 'Projectors, Screens & Video Processors' started by dogzdinner, Apr 6, 2005.
  1. dogzdinner
    dogzdinner
    Sep 9, 2003
    146
    Kettering, United Kingdom
    +3
    Evening all,
    I need a single input/dual output Component Video Box to connect onto the single component video output on my amplifier to feed seperate TV and Projector....does anyone know of a UK supplier for this requirement?
    Cheers,
    Tom...
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,572
    The Borders
    +3,029
    Hello dogzdinner
    We supply the Zektor Video Switcher range in the UK and the 4:1 YUV + Stereo or Digital audio switcher can be reverse wired as a 1:4 Switched Distribution amp - see http://www.zektor.com/hds4/index.html
    Key question is do you require both the TV and Projector on simultaneously?
    Best regards
    Joe
  3. dogzdinner
    dogzdinner
    Sep 9, 2003
    146
    +3
    Thanks for the reply....I don't need any audio switching though but I do need the opportunity to run both projector and TV if possible.
    £410 is a lot of money for something I'll only use a quarter of the features of!
    Thanks for replying though....is there anything else you can recommend?
    Cheers,
    Tom...
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,572
    The Borders
    +3,029
    dogzdinner
    If it was an 'either or' set-up then the sub £250 HDS4 would have done the trick - and just for the record the HDS4.2 (twin output) switcher is sub £400.00 :)
    If you require a 'both on' solution then its quite tricky getting something that 'only' does 1:2 YUV distribution - most kit will have more functionality than your looking for.
    One factor you need to consider being the length of your cable runs - the Zektor HDS4.2 for example has 1 x Passive + 1 x Driven Output; ideal if you have 1 x Short + 1 x Long cable run.
    A couple of options you could consider are:
    3 x Kramer PT-102VN @ £92.82 each (UK SRP).
    See http://www.kramerelectronics.com/indexes/pic.asp?p=PT-102VN
    1 x Kramer VP-72 @ £468.82 (UK SRP).
    See http://www.kramerelectronics.com/indexes/desc.asp?p=VP-72
    Best regards
    Joe
  5. dogzdinner
    dogzdinner
    Sep 9, 2003
    146
    +3
    I have one 'short' (5m) and one 'long' (12m) cable run....I could probably put up with having a one or the other scenario.....
    So how much would I be looking at including P&P?
    Cheers,
    Tom...
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,572
    The Borders
    +3,029
    Hello dogzdinner
    If you send me a PM I can send you pricing.
    Best regards
    Joe
