I need a hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by sweetnut, May 10, 2001.
  1. sweetnut
    sweetnut
    The hack to enable multi-region on a Toshiba SD2109E or 9B (unsure about the end bit)....handset hack please for this dvd,please.
  2. Confucius
    Confucius
    Feb 1, 2001
    2,148
    Oxford
    +132
    Sorry, I think most (all?) Toshiba's need a chip.
  3. spenceruk
    spenceruk
    The Toshiba 2109 cannot be modified for multi-region playback via a handset hack (unless someone knows otherwise!). I bought mine already modified (ie. "chipped") and I've been very pleased with it. If it's new you could try the supplier to see if they will chip it. If it's second hand you could always try Techtronics (provided it's not previously been chipped in any way). You might find the cost prohibitive though - it's always best to buy a machine that's already been modified!
  4. Fartpants
    Fartpants
    Why do people buy the machine then go looking for a hack?
