I need a 15metre rgb scart to rgb scart cable - any ideas?
Discussion in 'Cables & Switches' started by blue_tarragon, May 24, 2005.
  1. blue_tarragon
    blue_tarragon
    I have recently added a projector to my setup. I want to connect my system to the projector via scart and need a 15m cable.
    I have Xbox, PS2, DVD, Sky+ all going via a Quattro+ box and into a plasma.
    To also feed the signal to the projector I have ordered a JS Tech Active Video Buffer, so that all the kit can go into that via RGB scart and it will allow me to output to both the plasma and the projector.
    Currently I have a single video feed going to the projector and so want to replace that with a 15m scart cable.
    Really I just need some help locating a good 15m scart to scart cable and any help would be much appreciated.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,037
    The Borders
    +2,514
    blue tarragon
    VanDamme Red Series four core mini Multicore wired for RGB+Composite will do the trick and not cost a fortune - SUPRA AV6 is also good with metal SCART hoods and a price tag to match :)
    Best regards
    Joe
  3. blue_tarragon
    blue_tarragon
    Thanks Joe. You have mail.
