i-link cable
Discussion in 'Cables & Switches' started by Gezmondo, Jan 11, 2005.
  1. Gezmondo
    Gezmondo
    Mar 20, 2004
    348
    Harrogate
    Is there any preference to quality or are they all a std firewire cable?
    Just bought an AX10i and am connecting my DVD 757ai player to it.
    Just need assuring that a run of the mill pcworld cable will do the same job as a specialist cable.
    Gez. :lease:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,129
    Rainham Essex
    +2,392
    On a PC there is no point in spending more money on a so called better quality cable. As long as it works it will do what is needed.
    Although I have never used firewire on any AV equipment I have heard others that have said that getting a better cable did improve the sound quality. But I wouldn't say you need to spend a fortune on a cable.
    Mark.
  3. Gezmondo
    Gezmondo
    Mar 20, 2004
    348
    Harrogate
    I've bought a Belkin cable, only £20. Hopefully this will suffice! :smashin:
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +229
    im sure by now there are some good ones out there that are gold plated at the ends and insulated and such. As lond as you dont use a cheapo one it should be ok. You could always do a comparison.
