I-Link and Denon-Link???
Discussion in 'AV Receivers & Amplifiers' started by TheeNoMaD, Oct 4, 2004.
Tags:
  1. TheeNoMaD
    TheeNoMaD
    Hey hey
    I'm just curious, because i read on the pioneer website that the i-link is ieee-1394 which is firewire? isnt it? Also doesnt the ps2 use i-link and can that be used for audio while playing a dvd?
    As far as i know they are also uncompressed digital signals rather than the player converting them to analog and then back to digital again, much like hdmi or dvi.
    Cheers for any replies hope you can clear me up :thumbsup:
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    Yes iLink was origionally the Sony version of firewire or ieee1394 and are all exactly the same thing.
    Sorry never used a PS2
    Firewire is uncompressed digital and can carry audio & video signals, which is why it is the only connection for getting full quality sound and video from a DV camcorder onto a PC for editng.
    Mark.
  3. Roguey
    Roguey
    Aug 1, 2004
    203
    +13
    gets me u can get an reciever with it - cheaper than the DVD drive (denon). I would of thought the dvd drive would always be cheaper than the reciever has the reciever has to do some work, and is simpler than the reciever.
  4. MagicBoy
    MagicBoy
    Sep 19, 2003
    308
    +21
    i-Link (Firewire, IEEE1394 etc) on the PS2 was implemented initially to allow a simple way to connect multiple units together to play games, and perhaps allow additional peripherals to be connected in the future. The PS2 also has a USB connection in addition.
    The PS2 utilises a Toslink optical digital out for audio, which sends either PCM, or the Dolby/DTS bitstream for external decoding. The PS2 is not able to connect into an AV Amp/Processor using iLink that I'm aware of. iLink is purely a high speed digital interconnect and doesn't send a formatted signal like DVI/HDMI, so any additional functionality would be added via firmware/software.
  5. TheeNoMaD
    TheeNoMaD
    Coolio cheers guys
