I know this sounds stupid, but how do I format this Usb stick!?
Discussion in 'Computer Peripherals & Consumables' started by tpr007, Jul 20, 2015.
  1. tpr007
    tpr007
    Aug 9, 2003
    1,824
    Hong Kong
    +335
    it's a usb stick from a market in Hong Kong.
    It is recognised by the computer (it's my friends and they are using windows 7)
    However, it is labelled as rabbit TV, and comes preloaded with a. Rabbit .exe file to run some sort of Internet TV software.
    I can't see any settings in control panel or file manager to format the damn thing
    I'm taking it home tonight to try on my MacBook
    Any ideas?
  2. sparky10
    sparky10
    Mar 16, 2008
    1,480
    Bristol
    +257
    Hi, I don`t know about a Macbook, but in Windows I would just do the following:
    1. Plug USB into a USB port on your computer.
    2. Go to 'my computer' and you will see the USB drive.
    3. Right click on it with a mouse and select 'format from the options, that`s it.
    Hope this helps.
  3. tpr007
    tpr007
    Aug 9, 2003
    1,824
    Hong Kong
    +335
    no options.
    It's like the memory stick has been made to appear like a CD Rom drive :/
  4. sparky10
    sparky10
    Mar 16, 2008
    1,480
    Bristol
    +257
  5. razer1
    razer1
    Jan 5, 2011
    923
    46
    Leicester
    +162
    In mac, use disk utilities to format the drive. Applications > utilities > disk utilities.
    It might have been made to be bootable if its loading a .exe file so it automatically boots into the installer.
    Mac disk should clear it.
  6. tpr007
    tpr007
    Aug 9, 2003
    1,824
    Hong Kong
    +335
    The format option is greyed out. The stick is somehow read only.
    Never mind, I've given them the stick back and told them not to buy from market stalls!
