I keep getting an error message when I turn on my Laptop, help please if possible...
Discussion in 'Desktop & Laptop Computers Forum' started by Celtic Blood, May 7, 2007.
  1. Celtic Blood
    Celtic Blood
    About 10 seconds after windows starts, it says something like..
    C:/PROG~RUNDLL~PROG~RUNDLL.... Could not execute or something.
    It's obviously a partly deleted programme that was somehow selected to launch at my Windows start up.. I have no idea what it is though must be a mistake.
    It's easily closed and doesn't affect anything but it's annoying and means it takes slightly longer to boot my laptop up, does anyone have any clue how I can get into my startup folder/settings and delete it or something ?
    Cheers.
  2. Briggott
    Briggott
    May 21, 2006
    76
    London
    +8
    If you go to Start -> Run -> Msconfig.exe
    You will see the following screen; look for the program that is trying to be launched under the start up tab and untick it.
    This won't remove any software but it will prevent the annoying message.
    Hape this helps :)
  3. criticalmass
    criticalmass
    Feb 28, 2005
    548
    28
    Durham
    +40
    Open the registry editor (Start, Run, Regedit)
    Navigate to
    HKEY_LOCAL_MACHINE -> Software -> Microsoft -> Windows -> Current Version -> Run
    Everything that starts on boot is in there, have a look & see if anything looks familiar to the path of your error message, delete it and that should sort you out.
  4. Celtic Blood
    Celtic Blood
    Thanks both, it should be solved now just a bit unexperienced with that type off error as I've never had it.
    :smashin:
